AUX port as backup
hclisschennai
Hi Everybody,
I using Cisco 1841 Router with WIC-IT card connected to Leased Line primary link. I donot have any other module in the Router.
Shall i use the AUX port (interface Async1) to configure the dial backup . I have CDMA modem.So that when ever primary Lieased line is down, it will act as backup. Will this solution work?
Thanks in advance,
RK
Hello R.B. Kumar,
1) this may come from the usage of other A/S ports to build a terminal server
2) the aux is a single port
3) yes and you need the correct cabling setup from rj-45 to RS-232 and you need also specific commands like dialer in-band
see
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_backup_serial_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1000997
Hope to help
Giuseppe
paolo bevilacqua
Yes.
Giuseppe Larosa
Hello R Kumar,
this is a right way to do it.
the aux can be connected to a modem and has been thought for out of band management but it can be used for dial backup purposes.
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your response. It is indeed giving me confidence to go with this solution.
1.But then why people of using WIC-2A/S card for connecting external modem like PSTN modem. Why they are not using the AUX port which is inbuilt with Router
2.Is there any disadvantage in using AUX port compared to WIC-2A/S
3.Using AUX port shall I connect external CDMA modem/Phone with RS-232 interface
Hope you will help me in clarifying this point. Thanks in advance
RBK
Hello R.B. Kumar,
see
Hope to help
Giuseppe
