04-24-2008 11:06 PM - edited 03-03-2019 09:41 PM
Dear all,
i have a dedicated STM1 line between two sites, Is there any tool (Cisco or not Cisco) that measure the end to end availble bandwidth between these two sites
Best Regards
Solved! Go to Solution.
04-24-2008 11:59 PM
Hi, well u cn go for that, also u can configure the SNMP, and can get the same via NetFlow Analyzer. Thnaks Goutam Pls rate if it helps u!!!
04-24-2008 11:22 PM
Hi, You can configure Cisco Router with SNMP & the Non Cisco NetFlow Analyzer for B/W mangement. Thanks Goutam
04-24-2008 11:37 PM
I think the SNMP and the Netflow Analyzer will give me the bandwidth usage statistics; i need a tool that give me the available bandwidth from the ISP.
regards
04-24-2008 11:43 PM
Hi, Which kind of B/W you want to measure? LL, INTERNET, MPLS? Let me know!!! Thanks Goutam
04-24-2008 11:45 PM
i went to measure the available TCP/UDP traffic in the end to end STM1 line between two sites.
regards
04-24-2008 11:52 PM
Hi, NetFlow Analyzer is enough to measure the available TCP/UDP traffic. Thanks Goutam
04-24-2008 11:55 PM
Thank you,
but in this case i think i have to configure IP SLA and allow the NetFlow Analyzer to collect the information from IP SLA.
Is that right?
Reagards
04-24-2008 11:59 PM
