Bookmark
Subscribe
3045
Azure to ASA to Internet
I have successfully created the site to site between our ASA to Azure.
Azure can see our internal traffic and use the resources.
My question is, how can I make Azure goes through our ASA for internet?
Azure > ASA > Internet?
I have added it into our site to site connection for i.e the Azure VM. However it still didn't work - i have added into the ACL too.
Do I need a return ACL / NAT for it to work?
26 Replies 26
How did you configure that NAT ? Post the running config of your ASA and indicate which networks on the Azure side need Internet access through the ASA...
object-group network obj-local
network-object 10.0.0.0 255.255.0.0
network-object 106.10.248.151 255.255.255.255
exit
object-group network obj-remote
network-object 10.100.0.0 255.255.0.0
exit
nat (inside,outside-isp1) 1 source static obj-local obj-local destination static obj-remote
Azure (10.100.0.1) should connect to site to site to reach 106.10.248.151
do you have more than one ISP ? If not, make sure you have:
same-security-traffic permit intra-interface
configured on your ASA...
Otherwise, post the full running config of your ASA...
Thanks, i already have both
same-security-traffic permit inter-interface
However it is still not working and I have multiple ISPs
post the full running config of your ASA, otherwise it is just guesswork. Is the interface where the VPN terminates the same as the outgoing ISP you want to use for Internet access ?
try the below:
nat (inside,outside-isp1) source dynamic obj-remote
@Georg Pauwen wrote:
try the below:
done but still not working
Yup it is
since the incoming interface is the same as the outgoing, you actually do need hairpinning. Add:
nat (outside-isp2,outside-isp2) source dynamic obj-remote
Thanks.
I have added both
nat (inside,outside-isp1) source dynamic obj-remote interface
nat (outside-isp2,outside-isp2) source dynamic obj-remote interface
However, it is still not working..
remove this entry:
and just leave the other one in there...
nope, still not working.
post the output of:
show xlate
NAT from inside:10.0.0.0/16, 106.10.248.151,
106.10.248.151 to outside-isp2:10.0.0.0/16,
106.10.248.151, 106.10.248.151
flags sIT idle 0:00:04 timeout 0:00:00
NAT from outside-isp2:10.100.0.0/17 to inside:10.100.0.0/17
NAT from inside:10.0.0.0/16 to outside-isp1:10.0.0.0/16
flags sIT idle 0:00:16 timeout 0:00:00
