Back to Back T1, help!
mredel
I have the following config setup:
Cisco 2620 running IOS 12.2(3)
Cisco 3640 running IOS 12.2(28)
The 2620 is connected to the 3640 via a T1 crossover cable. The 2620 has a WIC-1DSU-T1 module and the 3640 is using 1FE-CT1-CSU network module. I have configured each router as such:
3640 config:
controller t1 0/0
framing esf
linecode b8zs
clock source internal
channel-group 0 1-24 speed 64
interface serial 0/0:0
ip address 10.1.1.2 255.255.255.0
encapsulation hdlc
2620 config:
ip address 10.1.1.1 255.255.255.0
encapsulation hdlc
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 clock source line
service-module t1 timeslots all speed 64
For the life of me, I cannot get the T1 circuit to come up, both ends give exactly the same error when looking at the T1 controller status:
"Transmitter is sending loss of frame
Receiver has loss of signal"
Any suggestions?
5 Replies 5
ggatten
You are using a X-over cable, right? To my knowledge there's no way to set the "DTE/DCE" in software with these interfaces. You need a X-over cable to do this. This is the pinout I use:
1 -> 5
2 -> 4
4 -> 2
5 -> 1
Gary
Gary
Thanks. I am using the crossover cable you indicated.
I think you can use only 1 timeslot (DS0) when configuring a channelized T1 (3640) to a fractional T1/DSU (2620).
Try reconfiguring the interfaces to see if this makes a difference:
(3640)
channel-group 0 1 speed 64
(2620)
service-module t1 timeslots 1
Also, I think it is easier to debug ppp encapsulation instead of hdlc.
Mustafa
scottmac
Level 10
Level 10
On one router, (config-Int)# add "intf-type DCE" and "clock rate <2000000>(-or whatever rate you want-).
The interface won't transmit unless you make the interface a DCE and give it a clock rate. Use the "?" to pull down the list of acceptable rates.
Also make sure your back-to-back cable is set so that the correct end connected to, and is labeled "DCE."
Back-to-back cables should have one end labeled "DCE" the other end is labeled "DTE."
Good Luck
Scott
The DCE/DTE settings are for Serial IF's - Sync / Async. When Using back-to-back T1 connections, this is not necessary. Not sure what it would do, but it certainly isn't needed.
The configs look right. At this point I'd:
- Use a T1 loopback and test both CSU/DSU's and make sure they work correctly.
- Verify the X-over cable is OK. Use an Ohm meter or make a new one or something.
- Maybe try changing roles on the clock source? Doubt it will help, but you never know. Also maybe use "1-24" vs. the "all" keyword in the config. Again, doubtful that's the problem, but you never no.
On my desk I have (3) 2610's connected similar to your config, all with WIC-1DSU-T1. One "core" router with (2) of them - thus connecting to the other (2) "remote" routers. Same basic config as yours and I have no probs.
When you get this resolved please post the resolution. I'd be curious what it ends up being.
Gary
