HSRP problem
mpabilona
We are frequently experiencing problem in our HSRP implementation. Please refer the logs below. Our workaround is to clear the arp cache and it goes normal temporary. Is it advicable to set the HSRP hello interval in higher than the default? What are the possible cause of the problem? Please present your suggestions to permanently solve our problem. Thank you.
Router1: Active Router
LO : 202.x.x.1
Port-Channel1
member0: FastEthernet4/0/1
member1: FastEthernet4/0/0
Port-Channel2
member0: FastEthernet0/0/1
member1: FastEthernet0/0/0
FastEthernet4/1/0
Router2: Standby Router
LO : 202.x.x.2
Port-Channel1
member0: FastEthernet4/0/0
member1: FastEthernet4/0/1
Port-Channel2
member0: FastEthernet1/0/0
member1: FastEthernet1/0/1
FastEthernet4/1/0
Router1:
Apr 4 15:11:25.596 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 2 state Standby -> Active
Apr 4 15:11:25.624 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 11 state Standby -> Active
Apr 4 15:11:25.640 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 6 state Standby -> Active
Apr 4 15:11:25.656 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 9 state Standby -> Active
Apr 4 15:11:25.704 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 3 state Standby -> Active
Apr 4 15:11:25.752 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 9 state Active -> Speak
Apr 4 15:11:25.796 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 3 state Active -> Speak
Apr 4 15:11:26.640 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 2 state Active -> Speak
Apr 4 15:11:26.672 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 11 state Active -> Speak
Apr 4 15:11:26.700 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 6 state Active -> Speak
Apr 4 15:11:36.912 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 2 state Standby -> Active
Router2 LOGS:
Apr 4 15:11:24.592 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 5 state Standby -> Active
Apr 4 15:11:24.592 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 10 state Standby -> Active
Apr 4 15:11:24.592 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 1 state Standby -> Active
Apr 4 15:11:24.596 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 7 state Standby -> Active
Apr 4 15:11:24.616 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 8 state Standby -> Active
Apr 4 15:11:24.620 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 4 state Standby -> Active
Apr 4 15:11:25.592 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 5 state Active -> Speak
Apr 4 15:11:25.596 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 10 state Active -> Speak
Apr 4 15:11:25.596 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 1 state Active -> Speak
Apr 4 15:11:25.596 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 8 state Active -> Speak
Apr 4 15:11:25.600 PHT: %HSRP-6-STATECHANGE: Port-channel1 Grp 4 state Active -> Speak
Apr 4 15:11:25.604 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 7 state Active -> Speak
Apr 4 15:11:56.296 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 5 state Standby -> Active
Apr 4 15:11:56.296 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 10 state Standby -> Active
Apr 4 15:11:56.300 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 1 state Standby -> Active
Apr 4 15:11:56.300 PHT: %HSRP-6-STATECHANGE: FastEthernet4/1/0 Grp 7 state Standby -> Active
5 Replies 5
rather than increasing the timeout, which might actually help, I would check first if there is excessive traffic on the network, or if there are physical problems. Can you post the output of 'debug standby' ?
GP
The only reason both are becoming active is because hello packets are getting lost somewhere in the middle.
And if it is not a bug it is mostly the physical layer problem when the hello packets are coming from active router to standby router could be due to congestion it is getting lost in middle.
The best troubleshootng procedure will be to hard set speed and duplex settings between your routers and switches to which both your HSRP routers are connected. I hope that should take care of the problem if by anychance you are not hitting some HSRP bugs.
Ankur
Ankur,
many thanks =)
The FastEthernet connection between the two HSRP routers through our switch was set to 100mb/s and full-duplex. The statistics below are the interface of the standby router that connects to the active router. We observed an amount of Input queue drops/flush and increasing broadcasts traffic, does it affect the communication ,via hello protocol,of the two routers ?
Router2#show interface FastEthernet4/1/0
FastEthernet4/1/0 is up, line protocol is up
Hardware is cyBus FastEthernet Interface, address is 000d.6574.3688 (bia 000d.6574.3688)
Description: HSRP 2
Internet address is 202.x.x.x/25
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 31/255, rxload 47/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:43:20
Input queue: 0/75/676/3658 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 18567000 bits/sec, 5027 packets/sec
5 minute output rate 12163000 bits/sec, 4332 packets/sec
30951863 packets input, 1239998521 bytes, 0 no buffer
Received 73277 broadcasts, 0 runts, 0 giants, 21 throttles
0 watchdog
24730230 packets output, 87932666 bytes, 0 underruns
0 lost carrier, 0 no carrier
GP,
From our standby router, we received the following log messages, does it causes failure to detect the hello message from the router1 (active) and resulted to change the states of our standby router to active?
Standby Router logs:
Apr 4 15:12:11.716 PHT: %LDP-5-NBRCHG: LDP Neighbor 202.x.x.1:0 is DOWN
Thanks.
indeed the failure of receib=ving the hello packet causes the state change.
As previously suggested by Arthur and me, I would check for congestion or physical problems on your network. Check the output of 'show interfaces' for any increased error counter especially FCS and CRC.
GP
