Backing up a ethernet wan
imranmohd
any method to backup an ethernet wan interface with isdn
tried to find something like object tracking or rtr
any doccument pls help.....
gpulos
Level 8
Level 8
there are a couple of different options for using ISDN as a backup link to a site if the WAN link fails.
floating static routes is one way and pretty easy to configure.
see the following link for more info on ISDN as a backup link with floating static routes:
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a00800a3b77.shtml
I believe if you are using dynamic routing protocol in the Ethernet WAN then floating static will be useful. However, if you are using static route for the primary connection then there will be a problem, due to the Ethernet may not down (next-hop still up) but the remote side down then the floating static will not work.
So, in your original question that the object tracking will be useful IF dynamic routing protocol is not used. Check below link for the object tracking that you can track the remote IP to ensure the connectivity is active.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541be.html
Hope this helps.
Hi!
Thanks for reply
Float static is not a solution as my primary link is RF which is terminated on ethernet.
The main problem is that router doesnt detect failure of primary when ethernet (RF) goes down..
So object tracking is an option to track ethernet interface but i m unable to find the doccuments on that.....
Not sure if you have seen this document or if you just have issues implememting it. It uses RTR to track the interfaces.
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
It does not use ISDN but you should be able to trigger the dialing based on intersting traffic.
