Backing up configurations to USB drive in ASA5505
somashekhar G
I connected USB drive (16 GB, FAT32) at front port of CISCO ASA5505 router. Tried to export running configurations to pen drive using following commands from CLI. I can't use ASDM since HTTP server is disabled on router.
copy /noconfirm running-config usbflash0 --> Showed some copy progress but nothing saved in USB drive.
copy /noconfirm running-config usbflash0:/new-running.cfg --> Displayed error
copy /noconfirm disk0:/new-running.cfg disk1:/new-running.cfg  --> Displayed error
I am able to save it to local flash drive of the router using below command,
copy /noconfirm running-config disk0:/new-running.cfg
Could you please help if I am missing anything.
Thanks...
Mark Elsen
 >...copy /noconfirm running-config usbflash0:/new-running.cfg --> Displayed error
              What do you mean by Displayed error -> What is the error that you see ?
 M.
Sorry, I missed to mention the error.
It is throwing below error
"ciscoasa# copy /noconfirm running-config usbflash0:/new-running.cfg
ERROR: % Invalid input detected at '^' marker.
It sounds like the USB drive isn't being recognized by the ASA. I think this works on an ASA as well as IOS, but I have found this command very helpful to see what file systems are available. "dir /all all"
