Backup Archive is not working
danilopasiani1
I am with a problem about "Archive" configuration.
I have this configuration below.
GA-CORE-4500#sh running-config | section archive
archive
path ftp://ftp_core:backupcisco@10.30.1.33/NETWORK/SW_GA-CORE-4500_
write-memory
time-period 10
I waiting for 10 minutes and the Archive is not starting automatically.
GA-CORE-4500#sh archive
The maximum archive configurations allowed is 10.
The next archive file will be named ftp://ftp_core:backupcisco@10.30.1.33/NETWORK/SW_GA-CORE-4500_-<timestamp>-0
Archive # Name
7
8
9
Someone know why is not working ?
When I try manual it works.
GA-CORE-4500#write memory
Building configuration...
Compressed configuration from 40622 bytes to 17033 bytes[OK]
Writing NETWORK/SW_GA-CORE-4500_May-18-2017-11-40-44-0
The next archive file will be named ftp://ftp_core:backupcisco@10.30.1.33/NETWORK/SW_GA-CORE-4500_-<timestamp>-1
Archive # Name
1 ftp://ftp_core:backupcisco@10.30.1.33/NETWORK/SW_GA-CORE-4500_May-18-2017-11-40-44-0 <- Most Recent
7
8
9
Hi Danilo,
Please check this link:
http://www.ciscozine.com/how-to-use-archive-command-to-save-configuration/
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hi Danilo,
This is the sintaxis I have used before:
archive
path scp://username:password@server_IP/config-$h-$t
write-memory
I was using a Linux server and it works perfectly try to adjust it to your requirements. Also remember to verify the connectivity from the devices IP as source to the server, using ping, telnet or traceroute.
Hope it is useful
Hi Julio,
When I try "write memory" manual it works.
So the connection with server it is ok.
Hi Danilo,
Cisco Freak
Level 4
Level 4
Your config looks right. I am not sure if you are hitting this bug:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCta68053
