QoS Marking with Service Obj. Group and/or Protocol
whistleblower14
hi guys,
I´m thinking about a QoS configuration, where I´d like to use either an object group-based ACL and/or (NBAR) protocols as match criteria on an IOS router... what I don`t understand is, when I´m using for example the following configruation;
object-group network TS-SRV
 host 10.100.100.1
 host 10.100.102.3
object-group network TS-HOS
host 192.168.2.12
object-group service SERV
 tcp-udp eq 3389
ip access-list extended MARK-QOS
 permit ip object-group SERV object-group TS-SRV object-group TS-HOS
class-map match-any MARK
 match access-group name MARK-QOS
 match protocol ms-wbt
will the port/protocol 3389/ms-wbt be matched as Source and Destination Port/Protocol or I´m wrong?
thanks for your help!
multiple match criteria inside a class-map will result in AND of all match criteria's
hi vivek,
first of all thanks for your reply, but what I mean is - if in either case
(1) match protocol ms-wbt
or
(2) ip access-list extended MARK-QOS
the Port in the statements is used/matched as Source and/or Destination or only Source?
It should match destination ports
...hmmm, is there also a way to match the source ports also that way?
I tried also to find some official documentation about this but I could`nt find anything about this - may you or somebody else have a link or reference?
