Backup Link over Multilink
Hi All,
We are having to WAN Link each 2 Mbps and we make it into bundle link as 4 Mbps. Also we are having 4 Mbps Biz fiber link. If any one of the WAN Link goes down, immediately backup Biz fiber link should trigger. Is it possible ? If it is , please tell me. Thank You.
Thanks & Regards
Senthil
Richard Burts
Senthil
I have not used it but I believe that there is a command in the configuration of the multilink that can specify the minimum number of links. If you set the minimum number of links to 2 then if either of the links in the bundle should go down then the entire multilink would go down and this should be able to trigger failover to the Biz fiber link as backup.
Rick
Rick
Dear Rick,
Thanks for your information.
Can u specify the necessary configuration changes under Multilink ? Waiting for your reply. Thank You.
Thanks  & Regards
Senthil
