Cannot connect to the Cisco 887W router via wireless Network
I recently installed a new Cisco 887W router @ my place and everything is working like a charm but the Macbook Air! The devices that are working currently are: iPhone, iPad, HP laptop, Nokia mobile phone.
I  have checked two Macbook Air so far and both have the same problem with  the wireless network! I even manually added the SSID to "Airport  Preferred network setting" but still couldn't make it to work!
So the  issue is the Macbook Air can detect the SSIDs intermittently however  when it detects the SSID it doesn not connect to the wireless network  and it comes up with the error of "connection timeout".  I have used the  command "show dot11 association" to see if the Macbook air will be  detected on the router side unfortunately that was in vain.
The  setting that I have on the router under SSID is "guest-mode" i.e. it  broadcasts the SSID, security is WPA 2 with AES encyrption.
Any ideas or thoughts how to fix the issue?
5 Replies 5
paolo bevilacqua
Post relevant config.
Vlan 30 >>>RadioDot 11 0.30>>>>Gigabit 0.2>>>>bridge group 2
Vlan 200>>RadioDot 11 0.200>>>Gigabit 0.1>>>>bridge group 1 (native Vlan)
Router Side:
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.200.1
ip dhcp pool ccp-pool
  import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name viper
dns-server 203.12.160.35 203.12.160.36 203.12.160.37
  lease 0 4
ip dhcp pool Wlan-Bitter
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
domain-name viper
lease 0 4
ip dhcp pool Wlan-Serendipity
  network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
domain-name viper
lease 0 4
interface wlan-ap0
description Service module interface to manage the embedded AP
  ip unnumbered Vlan200
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport trunk native vlan 200
switchport mode trunk
no ip address
interface Vlan30
description WLAN-Serendipity 192.168.30.0 / 24
ip address 192.168.30.1 255.255.255.0
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
  ip tcp adjust-mss 1360
load-interval 30
interface Vlan200
description *** BITTER LAYER 3 INTERFACE ***
ip address 192.168.200.1 255.255.255.0
no ip unreachables
ip flow ingress
ip flow egress
  ip nat inside
load-interval 30
AP side
dot11 ssid Bitter
   vlan 200
   authentication open
   authentication key-management wpa
    mbssid guest-mode
   wpa-psk ascii 7 xxxxxxx
dot11 ssid Serendipity
   vlan 30
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxxxxxxx
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
  no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.200
encapsulation dot1Q 200 native
no ip route-cache
bridge-group 1
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
  no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
  no ip address
no ip route-cache
interface GigabitEthernet0.1
description $ETH-LAN$
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
no ip address
  no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip default-gateway 192.168.200.1
ip http server
ip http authentication local
ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
No dot11radio0 config ?
Anyway, should be
authentication shared
Hi Arsalan,
have you resolved it ? i am haveing same problem.
thanks
Rejohn Cuares
Level 4
Level 4
Check this link which contains the solution: https://discussions.apple.com/thread/3366331?start=0&tstart=0
Please rate replies and mark question as "answered" if applicable.
