backup wan connection not work
b1723651
Hi all,
I'm testing ADSL+3G dualwan, first try to setup ADSL as primary and 3G as backup line. I've setup Fix IP + 3G to work with similar commands. (that is if I unpluged cable of "fix ip" line, all traffices will goes to 3G)
but when I replase "fix ip" line with ADSL, it does not work anymore, can anyone help me diagnose what was wrong? thanks!
Building configuration...
Current configuration : 2807 bytes
! Last configuration change at 12:24:03 UTC Thu Dec 30 2010 by rr
version 15.0
hostname Store
boot-start-marker
boot system flash:/c2800nm-advsecurityk9-mz.150-1.M4.bin
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
chat-script gsm "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
license udi pid CISCO2811 sn FHKxxxxxx
archive
log config
  hidekeys
username rrr privilege 15 secret 5 $1$xxx
redundancy
no ip ftp passive
track 1 ip sla 1 reachability
interface FastEthernet0/0
ip address 172.16.0.201 255.255.192.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-WAN$
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Cellular0/2/0
no ip address
ip nat outside
encapsulation ppp
dialer in-band
dialer pool-member 2
async mode interactive
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname username
ppp chap password 0 password
ppp pap sent-username usrename password 0 password
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 2
dialer idle-timeout 0
dialer string gsm
dialer persistent
ppp chap hostname 3gnet
ppp chap password 0 3gnet
ppp ipcp dns request
ip local policy route-map track-primary-if
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1 253
ip sla 1
icmp-echo 8.8.8.8 source-interface FastEthernet0/1
ip sla schedule 1 life forever start-time now
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 172.16.0.0 0.0.63.255
access-list 100 remark CCP_ACL Category=0
access-list 100 permit icmp any host 8.8.8.8
dialer-list 1 protocol ip permit
route-map track-primary-if permit 1
match ip address 100
set interface FastEthernet0/1 Null0
control-plane
line con 0
line aux 0
line 0/2/0
script dialer gsm
modem InOut
no exec
transport input all
rxspeed 3600000
txspeed 384000
line vty 0 4
privilege level 15
login local
transport input telnet
scheduler allocate 20000 1000
end
Shelley Bhalla
Level 3
Level 3
A couple of things to check:
1. When you remove the cable, See what the NAT translations are. Do they clear or not. Try to clear the NAT translations
2. Check the default route once the ADSL cable is taken out does the default route point to the new dialer (3g)
3. Does it work when you clear the dialer interface (ADSL) clear inter dial 0.
4. What happens if you shut the ATM port down , Still same results?
If all these wont give you a hint, I think a Cisco TAC case should be open for further support.
Shelley
Cisco TAC.
