bad image and register 0x2101 cause continuous reboot
willinsau
My router is Cisco 3640,yesterday I found a new image from web and updated it. Today when I reboot it ,it shows
image unzip failed ,after 4 times reboot ,it change to  Rommon 1> model.
I want to solve the issue,so view the internet,and a post
told me change the freg to 0x2101,I did it ,and reboot.but now it reboot again and again, can not reenter recomm model
it repeats shows:
 I try to use CTRL+BREAK when it boots in 20 sec
but it doesn't work
I think 0x2101 cause it try to boot from the image,but the image is corrupt,and 0x2101 do not lead to rommon
so it boots again and again , I can not break it
how can I do now?
balaji.bandi
what was the version was old what version you trying to upgrade.
When you get Rommon 1>  - then follow  ROMMON recovery :
https://www.cisco.com/c/en/us/support/docs/routers/3600-series-multiservice-platforms/15080-recovery-c3600.html
BB
sorry, the problem now is it could not  get Rommon 1>
It reboot again and again,I think I changed the register to
0x2101 cause the
Boots into bootstrap
Ignores break
Boots into ROM if initial boot fails
9600 console baud rate
Now the issue is the router can not get Rommon 1>
how could I do ?
anyway to reset the register by hardware??
tkx
Leo Laohoo
Why?
The 3640 router stores it's files in the PCMCIA cards, right?
What happens if the PCMCIA cards are removed and the router gets powered up?
