Band limitation on EM7455 in IR1101 on LTE no longer possible
sppy
Hello everyone,
I have received a new batch of EM7455 (P-LTEA-ES V02) plug-in modems, which I use in combination with the IR1101. I have tried to set a limit on the LTE bands 8 & 20, but I only have the possibility to apply this to UMTS bands, is this a bug or is it due to the firmware on the modem?
Modem:
Hardware Information
Modem Firmware Version = SWI9X30C_02.33.03.00
Device Model ID = EM7455
Router:
Cisco IOS XE Software, Version 17.09.01
test-IR1101(config-controller)#lte modem band-select indices ?
umts3g Specify the 3g indices
test-IR1101(config-controller)#$and-select indices "8 20" Slot 0
lte modem band-select indices "8 20" Slot 0
% Invalid input detected at '^' marker.
gw-de-test-IR1101(config-controller)#
Thanks you for your help
0 Replies 0
