BGP MPLS Route Reflector issue
Ammartehsein
I am having an issue in the MPLS Route reflector config. The route reflector is not receiving any mp-bgp routes.
RR config:
router bgp 500
no synchronization
bgp router-id 70.70.70.70
bgp log-neighbor-changes
neighbor MPLS peer-group
neighbor MPLS remote-as 500
neighbor MPLS update-source Loopback1
neighbor MPLS route-reflector-client
neighbor 10.10.10.10 peer-group MPLS
neighbor 20.20.20.20 peer-group MPLS
neighbor 30.30.30.30 peer-group MPLS
no auto-summary
address-family vpnv4
neighbor MPLS send-community extended
neighbor 10.10.10.10 activate
neighbor 20.20.20.20 activate
neighbor 30.30.30.30 activate
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.10.10.10 4 500 53 53 1 0 0 00:43:04 0
20.20.20.20 4 500 52 52 1 0 0 00:43:06 0
30.30.30.30 4 500 54 52 1 0 0 00:42:56 0
RR#sh ip bgp vpnv4
RR#sh ip bgp vpnv4 all
RR#
PE1 config:
router bgp 500
no synchronization
bgp router-id 10.10.10.10
neighbor 70.70.70.70 remote-as 500
neighbor 70.70.70.70 update-source Loopback1
no auto-summary
neighbor 70.70.70.70 activate
neighbor 70.70.70.70 send-community extended
exit-address-family
address-family ipv4 vrf CUST-A
neighbor 1.1.1.1 remote-as 1000
neighbor 1.1.1.1 activate
no synchronization
exit-address-family
PE1#sh ip bgp summary
BGP router identifier 10.10.10.10, local AS number 500
70.70.70.70 4 500 50 50 1 0 0 00:39:27 0
PE1#sh ip route vrf CUST-A
Routing Table: CUST-A
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/30 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, FastEthernet0/0
100.0.0.0/32 is subnetted, 1 subnets
B 100.100.100.100 [20/0] via 1.1.1.1, 00:18:10
This worked for me
6 Replies 6
one more step need (additional to what you config)
under
address family vpnv4 unicast
neighbor x.x.x.x route-reflect-client
this need in RR of bgp
MHM
RR(config-router-af)#neighbor 10.10.10.10 route-reflector-client
% Activate the neighbor for the address family first
This is the error
This neighbor must activate via
Address family vpnv4 unicast
Neighbor 10.10.10.10 activate
The  you can config route-reflect-client via
Neighbor 10.10.10.10 route-reflect-client
MHM
This worked for me
You need to config route reflect under vpnv4
MHM
what if you activate the peer group instead of the individual peers ?
So instead of:
try:
neighbor MPLS activate
