Bandwidth Aggregration
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-08-2013 03:59 AM - edited 03-04-2019 07:31 PM
I want to aggregrate the bandwidth of 3 ISP. I have of link of ISP A, ISP B and ISP C of 10 mbps, 20 mbps and 30 mbps respectively. I have a point to point connection of these links and want to network in such a way that I get the total bandwidth of 60 mbps at a time. On a failure of any ISP link the network should work with the bandwidth deducation of that link. Is this possible or not. I have got only one ip address at the remote side and needs to trasfer the data with the single protocol.
Mero
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2013 06:09 AM
Hello Mero,
You can have resiliency in case of link failure and path determination but as for aggregating 3 links from 3 different providers - that not possible ( well I am assuming this is the case unless someone on here can explain otherwise)
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2013 07:14 AM
Hi Paul,
I have the L2 Intranet link of 3 ISP's. Is their any load balancing technique which can fulfill my requirement.
Mero
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2013 08:11 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You mention L2, but if you had a L3 hand-off and routers that support it, OER/PfR might load balance as you want.
