bandwidth allocation in cisco 2921
zeuscyril
Level 7
Level 7
hi all,
i have 16 mb internet line from the ISP.
i have different VLANs created in the switch 3750-x and default route pointed to cisco 2921 router.
i have 2 vlan for guest for that particular subnet i need to allocate only 3mb internet from total 16 mb and rest i need to use for my other office subnets
how i can acheive this using qos on cisco 2921
thanks
cyril
Nagendra Kumar Nainar
Do you have 2 differnet vlan as ingress interface or just one on 2921?. Do you want the accumulated traffic from both vlan not exceed 3 mb or each vlan not to exceed 3 mb?.
Accordingly you can configure ingress with policing or egress with shapng/policing.
-Nagendra
hi Nage,
i am using 2921 as a transit network ,
it doesnt have multiple sub interface for VLAN , all  VLAN's are created in switch.
2921 has one interface IP in the one of the VLAN range
yes both vlan not exceed 3mb
You can configure a class-map to match the traffic originated from both the source as below,
ip access-list extended GUEST
permit ip <vlan1-network> <mask> any
permit ip <vlan2-network> <mask> any
class-map GUEST
match ip address GUEST
Now configure a policy-map with this class-map and police it to 3 mb. The remaining traffic will go via class default while the traffic from guest vlans will be limited to 3 mb.
Apply this policy-map in ingress direction.
BTW, this is under assumption that the traffic from guest vlan is only towards internet.
-Nagendra
zeuscyril
Level 7
Level 7
this is what i confiured,
class-map match-all Guest
 match access-group name HA-Guest
policy-map Guest
 class Guest
  police 25165500 conform-action transmit  exceed-action drop
 class class-default
interface GigabitEthernet0/1
 description ========LAN Connected to Switch======
 ip address 10.31.100.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 service-policy output Guest
ip access-list extended HA-Guest
 permit ip 192.168.151.0 0.0.0.255 any
 permit ip 192.168.152.0 0.0.0.255 any
this is what i confiured , guest will access only internet nothing else.
