bandwidth capacity for serial interfaces
mohammed hashim
hi all
what is the maximum capacity of WAN serial interfaces todays can be provided ?
thanks,
7 Replies 7
johnlloyd_13
Level 9
Level 9
hi,
the highest i've seen so far (and provisioned in our WAN environment) is a 4 meg.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Do you mean an interface on a Cisco router labeled "serial"?  I think I recall Cisco's HSSI might show as a "serial" interface - recall using one (years ago) for DS3 handoff - i.e. 45 Mbps.
ah yes, joseph is right.
we also have DS3s on our ASRs on a SPA card.
the 45 meg would be definitely the highest that can be provisioned for a serial link.
mohammed hashim
and if we talk about frame-relay and the maximum interface bandwidth can be provided nowadays with cisco devices !
does it support only up to 45 mbps ?
thanks,
Disclaimer
Posting
The available bandwidth of frame-relay depends on your WAN provider.  They might offer Ethernet interface hand-offs.  However a native frame-relay interface might be limited to DS3/ES3.
The HSSI interface appears it will support up to STS-1, 51.84 Mbps.
Danilo Dy
In this Protocol Overhead page, it will provide you more information on how much you will actually get http://sd.wareonearth.com/~phil/net/overhead/
wilmar.jaimes
Hola Shako_alyom,
Puedes verificar en el siguiente enlace:
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/datasheet_c78-491363.html
En la tabla 5, puedes observar que dependiendo del hardware que tengas el máximo ancho de banda varía.
Saludos,
