Bandwidth Command
GRANT3779
Hi All,
On a VPN tunnel Interface if I have side A on a 10Mb Down / 5Mb Up connection and Side B on a 4Mb Down / 0.5Mb Up, what would be best practise on the Bandwidth command within a tunnel Interface? It was noted before that if the two VPN ends are on different speeds, then use the lowest of them. What speed should be reference if up/down are different?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Well since Cisco's bandwidth statement assumes symmetrical bandwidth, you can either chose which ever bandwidth is most important to you for monitoring against 100% usage, or you can chose the higher value (which helps avoid usage appearing to exceed 100%).
However, bandwidth statement might be used by other protocols.  For such, you would set as they might need.  For example (generally by default), Cisco's OSPF uses the bandwidth statement for setting it's egress OSPF cost.  So, for such, you would want to set the bandwidth statement to match your egress (up) bandwidth.
