Bandwidth Limit/Restriction for a specific source<>destination
Hello All,
I have two sites. We have router 4451x at site A and 2911 at site B. there is a job scheduled between host A(192.168.10.55)<>host B (172.16.20.101) on daily basis which is bandwidth intensive. I want to restrict the bandwidth for the traffic between these 2 hosts to 2 Mbps. Could anyone suggest that below configuration is correct or need any changes. I was thinking to apply these configuration on router 4451. Please suggest
ip access-list extended 105
permit ip host 192.168.10.55 host 172.16.20.101
class-map 10.55<>20.101
match access-group 105
policy-map A<>B
class 10.55<>20.101 (class-map name)
shape average 2000000(2 Mbps)
policy-map BW_A<>B
class class-defaults
service-policy A<>B
int gig0/1
service-policy output BW_A<>B
5 Replies 5
balaji.bandi
I use below exmaple for testng.  ( change the source and interace accordingly)
SITE A
Acces-list 100 permit ip host 192.168.10.55 host 172.16.20.101
class-map match-any TEST
match access-group 100
policy-map LIMIT-2MB
class TEST
bandwidth 2000
interface Gigx/x
Service-policy output LIMIT-2MB
SITEB
Acces-list 100 permit ip host 172.16.20.101 host 192.168.10.55
class TEST
bandwidth 2000
interface Gix/x
https://www.cisco.com/c/en/us/support/docs/quality-of-service-qos/qos-packet-marking/10100-priorityvsbw.html
BB
Hello balaji,
Thanks for your suggestion. I will try and update it meets our goal.
Joseph W. Doherty
Hmm, unclear why you're using a two level policy.  Just using
int gig0/1
service-policy output A<>B
should meet your goal.
That said, something like what Balaji posted might be a "better" approach.  Balaji's approach doesn't limit this traffic to 2Mbps, it guarantees (2 Mbps).  I.e. the restricted class can use more bandwidth if it's otherwise not being used.  (NB: although Balaji's class-name is "LIMIT-2MB", the class bandwidth statement sets a floor not a ceiling for bandwidth usage.)
Personally, if the intensive bandwidth usage flow isn't time sensitive, I place it into a class with minimum bandwidth allocation.  This keeps it "behind" other traffic but allows it to use all otherwise unused bandwidth.
E.g.:
policy-map A<>B
bandwidth 1 percent
class class-default
bandwidth 99 percent
Hello Joseph,
This scheduled job has to be completed within a time frame So I was thinking to give it 2-3 Mbps bandwidth. As per your suggestion below configuration should work:
policy-map A<>B
int gig0/1
If you have a time constraint, you can still use a policy, w/o a shaper (or policer), to guarantee whatever minimum bandwidth allowance you believe you need.  Again, such a policy will allow this traffic to take advantage of otherwise unused bandwidth.  I.e. the data transfer might complete sooner but it should always complete in its time allowance.  Also again, even though you're not capping this flows bandwidth usage, such a policy will also guarantee other traffic can have all but the 2 (or 3) Mbps you've guaranteed for this traffic.  I.e. basically the same behavior/guarantee for all the other traffic without capping some traffic.
The forgoing aside, yes to your question.  I.e. your latest configuration should work too.
