bandwidth management_suite
jponcisco1
i am having 5mbps  from my ISP. I would like to dedicate 1mbps to one particular user. The rest of all users will share the remaining 4mbps. How can i proceed from the router or LAN switch ?
2 Accepted Solutions
Just implement CBWFQ.
there is not even need for shaping or policing. You just will write a class matching  your customer and you will set a bandwidth value of 1 Mbps ... If the other customers have no requirements you will leave all the remainiing 4 mbps in the class-default (best effort model).
Suggestion, since you will be defining a class for your customer just define a class for yourself too. 5 mbps are not so many and in case of congestion you would have 100kbps for example assured for your management.
i'd prefer to do this on the router....
Alessio
Thank u Alessio. The problem has been fixed.
Alessio
Dear Alessio.
Good day.
I hope you are fine. Let me know if you are available. I need your support
Kind regards
J.P
BTW, I would say Alessio's suggested solution might be less than 100% accurate.
