BANDWIDTH MANAGEMENT
kennytwistj
Hello, am setting up an ISP and I want to know if it's possible to use a cisco switchports to bandwidth manage clients, and if it's not possible,any other good solution that can be suggested. thank you
it depends on what Cisco switch models you are using, but mots of them allow you to limit bandwidth. There usually is some sort of QoS and port management such as rate limiting available.
This guide is a good start:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfcar.html
