Bandwidth settings Cisco Routers and Speed Related Problems
tariqmansoor
HI Team, It sems like i am caught up in bandwidth settings on Cisco router 837. I have ADSL2+connectionand, and have configured Cisco 837 which is working ok and conencting fine but have slow speed. I think this only support ADSL1, and carrier says taht speed is correct for adsl1 but i think there might be issues with bandwidth settings as i see all diferent settings every where. i.e on ATM Interface , ATM0.1 Interface, Dialer Interface. Below is what i have configured as bandwitdh
Interface atm0.1 is the actual interface configured with ADSL credentials.
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
Description: Internet Link Fixed IP
Internet address is a.a.a.a
MTU 1400 bytes, BW 56 Kbit/sec, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Interface is bound to Vi2
Last input never, output never, output hang never
Last clearing of "show interface" counters 15:39:15
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 81
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
110180 packets input, 40725000 bytes
117189 packets output, 13618612 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1400 bytes, BW 100000 Kbit/sec, DLY 20000 usec,
ROUTER#sh int atm0
ATM0 is up, line protocol is up
Hardware is PQUICC_SAR (with Alcatel ADSL Module)
MTU 1500 bytes, sub MTU 1500, BW 800 Kbit/sec, DLY 80 usec,
reliability 255/255, txload 3/255, rxload 36/255
ROUTER#sh int atm0.1
ATM0.1 is up, line protocol is up
Description: Link to PowerTel Internet Connection
MTU 1500 bytes, BW 800 Kbit/sec, DLY 80 usec,
reliability 255/255, txload 5/255, rxload 71/255
The bandwidth command doesn't affect the actual access rate. This parameter allows you for example to influence IGP best-path decision like OSPF or EIGRP which use the bandwidth defined on the interface for the cost calculation.
Laurent.
7 Replies 7
Laurent Aubert
837 doesn't support ADSL2/ADSL2+ connection. Only the 857 and 876 routers are able to synchronize with ADSL2
Laurent.
Thanks Laurent,
If this was a ADSL1, Changing of Which Interface bandwidth would effect the speed. of course speed can not increase than the ADSL1 speed itself. but if the interface is configured on less bandwith , say 64kbps, it would effect the speed ?
I am just scratching my head around, what these bandwitdhs , on these interfaces mean when the connection is adsl1 connection ?
Thanks for your Assistance :)
Laurent.
Thanks Laurent,
It will be great if i can also get my confusion vanished with the MTU size.
I get different MTU Size on all three Interfaces.
MTU on atm0: 1500 Bytes
MTU on atm0.1: 1500 Bytes
MTU on Dialer1: 1400 Bytes
Can you please tell which MTU Size effect the browsing. decreasing the MTU size on Dialler1 Interface did not fixed the issue of problem in Microsoft website loading.
Thanks Laurent,
Thanks Laurent,
on dialer1, configure mtu 1492.
on the lan interface, configure ip tcp mss-adjust 1452.
