Bandwidth Traffic Management
Anand Narayana
Level 6
Level 6
i have got 1700 series internet router, gone threw several documents in cisco, was confused, so my requirement, i wanted to make use of 30% of HTTP traffic,50% of FTP traffic & rest traffic 20%, so any working configuration those who have already done can be more useful for me to go head in doing this for our internet router.
5 Replies 5
spremkumar
Level 9
Level 9
Hi Anand
Are you trying to configure QOS policy for the different classes of traffic ?
regds
Yeah QoS policy only.
Hieu Cao
Level 4
Level 4
Cisco usually recommend that you reserve a minimum of 25% of your bandwith for the default class to handle all other network traffic, and a minimum 5% of bw for ip routing.
class-map match-any Network-Control
match ip dscp cs6
match ip dscp cs2
class-map match-any Critical-Data
match ip protocol http
match ip protocol ftp
policy-map Lan-Traffic
class Nework-Control
bandwitdh percent 5
class Critical-Data
set ip dscp af21
bandwidth percent 70
class class-default
bandwith percent 25
random-detect dscp-based
Use "max-reserved bandwith 100" to override the 75% default bandwith limit, then
Use "service-policy output Lan-Traffic" command on your serial interface to enable the policy-map from above, and
Use "show policy-map inteface xxx " to verify bandwith usage and hits.
HTH,
hieu
Hi Hieu,
thankz for ur reply, but the commands which u hav provided doesn't work on my 1700 series router "c1700-y-mz.120-7.T"
Which specific commands that do not work? Maybe the 1700 series router doesn't have enough nvram to handle the qos, because I am implementing the similar qos in my routers (2800 series)...
Or you can try something like this..
class-map match-any HTTP-FTP
match access-group 110
policy-map LAN-TRAFFIC
class HTTP-FTP
bandwith percent 50
class class-default
fair-queue
access-list 110 permit tcp any any eq 80
access-list 110 permit tcp any any eq 21
access-list 110 permit ip any any
