Bandwidth
w_basheer
Hi;
there's a software or a method can i use to check the available bandwidth on a link?
or per interface.
Basheer,
Use network monitoring tools like MRTG, SOlarwinds etc
www.mrtg.com
www.solarwinds.net
Narayan
imnilesh
basheer;
there are sevral wyas to minotor the available bandwith on link.
one is manually you can check by doing sh int interface no.
or you can install mrtg which is open source software to monitor and keep record of bandwidth.
or you can install prtg which is window base software for which you have to spend some money.
gurpreetabdal
try doing FTP from ISP network or other network destination u want to test to.
use IE or firefox, that can tell u rate while downloading.
Basheer,
www.mrtg.com
www.solarwinds.net
Narayan
I'd recommend IE over Firefox because IE shows the instantaneous transfer rate rather than the average rate. The average rate Firefox displays is usually too high because the startup rate is typically much higher than the average rate and skews the displayed rate.
