Basic configuration of Cisco ASR 1002 configuration
ashz14387
Provide me a basic configuration of ASR 1002 router which has the following protocol active
1. DHCP
2. NAT ( PAT, DNAT, SNAT)
3. HSRP
4. ACL
5. Routing protocols like OSPF and BGP
Kindly share me the configuration for the above mentioned. Thanks in advance
pieterh
may I suggest you apply for a Cisco CCNA training or similar ?
Funny, i do have CCNA certification and i do know how to configure all the mentioned above and i am also sry for not providing the question that conveys my requirement. I just want to know that configuring steps involved in the above mentioned protocols is same as cisco router 7200 for Cisco ASR.
pieterh
7200 IOS Version 12.x but retired
 Cisco IOS Software Release 12.4(11)T - Retirement Notification - Cisco
1002 IOS-XE version 16.x
Cisco ASR 1000 Series Aggregation Services Routers - Configuration Guides - Cisco
-> the steps will be the same
and most commands will be the same, though there will be some command differences
Thanks for the reply
