Basic LAN to WAN NAT for Internet Access
patpawlowski
Hey guys, I'm new to IOS and Cisco but pretty good with the IPTables firewall that we are trying to replace. I have Cisco 1700 with a T1 card. I have configured the T1 to at least come up and I think I have the WAN side of the router configured correctly:
ip routing
ip default-network 64.7.10.0
......other stuff......
interface Serial0/0.1 point-to-point
description connected to Internet
ip address 64.7.10.193 255.255.255.0
ip name-server 66.80.130.23 66.80.131.5
ip nat outside
frame-relay interface-dlci 16 IETF
At least it comes up!
I have been trying to configure our source NAT, where the router/gateway replaces the 10.0.0.x source address with our public 207.145.33.194 and then undoes it for the returning packets. But I just haven't been able to decifer the manual. Our internal network is 10.0.0.0/24 and I am trying to SNAT it to public 207.145.33.194. I have looked over and over the manual at the nat commands but cannot seem to figure out which format to use. I have the inside and outside interfaces set, that was easy.I figure something like this for the actuall address translation:
ip nat inside source static network 10.0.0.1 207.145.33.194 255.255.255.192
But I don't believe that's correct.
Thanks in advance for any help.
-pat
Hello Pat,
try the following config:
ip nat pool INTERNET 207.145.33.194 207.145.33.194
ip nat inside source list 1 pool INTERNET overload
access-list 1 permit 10.0.0.0 0.255.255.255
If you use another mask on your 10.0.0.0 network, change the access-list wildcard accordingly...
HTH,
GP
Thanks for the reply,
Just to clarify, the following line:
the 0.255.255.255 indicates wild cards, sort of the opposite of a mask? Our mask is 255.255.255.0 so I assume, per comment, that I would use 0.0.0.255?
Thanks again for the help.
