basic mpls VPN operation
Mohit Chauhan
I am trying to set up a basic lab on gns to have some hands on mpls VPN environment
I created an ISP cloud running OSPF and mpls between all the P and PE routers.
On the PE routers I created loop backs representing diff customers on different VRFs.
I am running bgp on the PE routers and can see the other side route learned via BGP. When I say other side I mean the other end PE has exactly the same set up with loopbacks in the respective VRFs. So say on one PE I have VRF A with lo1 and ip 192.168.1.1/24 and the other end has lo1 in VRF A with ip 192.168.2.1/24.
Now when I do sh ip route VRF A on one PE, I do see the other route learnt via bgp.
Now the issue is for some reason I cannot ping the other end. I can ping my local ip only.
I ran trace but it doesn't show any ip at all, all asterisks only.
I have a feeling I am missing something here.... I will send snapshot of the config very soon but I thought atleast I can put in the description of the issue.
Let me know if you have any suggestion in the meanwhile I get back with config details.
Reg
Mohit
8 Replies 8
usasigcis
have you redistributed the routes???
Could you post here the configs?
I suppose you configured MP-BGP VPNV4 between the PE's (from the /32 loopbacks which are known by the IGP) and LDP is working in the cloud.
Best Regards,
Jose.
Hi guys
Sorry for the late reply.
I did fixed the problem late last night so did not get time to send the config out.
I still need to confirm what were the root cause and would let you know here.
However, just a quick Q, how is the below different to each other?
Address-family vpnv4
And
Address-family vpnv4 unicast
I do remember missing the unicast keyword when I activate neighbour for the mp VPN.....looking at the config guide it shows the keyword used.
You reckon that may cause the issue?
Cheers,
Mohit
Hi Mohit,
Only unicast is enabled by default. So "address-family vpnv4" and "address-family vpnv4 unicast" are equivalent.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
hi all,
thanks everyone for your inputs.
the reason the pings were not working was cos one of the interfaces on the P router was missing "mpls ip".
Now i can ping all the way through from one loopback (vrf A) on the PE to the other loopback (vrf A) on the other PE.
the thing which I am not able to dissect is when I execute this command below:
          R5#sh bgp vpnv4 unicast all
        Network          Next Hop            Metric LocPrf Weight Path
     Route Distinguisher: 65000:1
         *>i192.168.4.0      4.4.4.4                  0    100      0 ?
     Route Distinguisher: 65001:1 (default for vrf A)
     *> 192.168.5.0      0.0.0.0                  0         32768 ?
...................................why I see 192.168.4.0 at two places?
the config of the two PE is below for reference sake:
*******************************R4 (one PE)********************************
ip vrf A
rd 65000:1
route-target export 1:1
route-target import 1:1
ip vrf B
rd 65000:2
route-target export 1:2
route-target import 1:2
router bgp 65000
no synchronization
bgp log-neighbor-changes
neighbor 5.5.5.5 remote-as 65000
neighbor 5.5.5.5 update-source Loopback1
no auto-summary
  neighbor 5.5.5.5 activate
  neighbor 5.5.5.5 send-community extended
exit-address-family
address-family ipv4 vrf B
  redistribute connected
  no synchronization
exit-address-family
address-family ipv4 vrf A
  no synchronization
exit-address-family
*******************************R5 (second PE)********************************
ip vrf A
rd 65001:1
ip vrf B
rd 65001:2
router bgp 65000
no synchronization
neighbor 4.4.4.4 remote-as 65000
neighbor 4.4.4.4 update-source Loopback1
no auto-summary
  neighbor 4.4.4.4 activate
  neighbor 4.4.4.4 send-community extended
exit-address-family
  no synchronization
exit-address-family
  no synchronization
exit-address-family
Mohit
If mpls ip was missing on one device, LDP was not working there and the LSP was broken at that point.
The reason for this:
Is because you have two different VPNv4 routes. Remember that VPNv4 routes are the 32 bit IPv4 prefix + 64 bit Route Distinguisher, which makes the prefixes unique in the cloud. As you have applied a different RD in each PE, you see the VPNv4 route coming from the other PE with the RD 65000:1 and the same IPv4 prefix with the RD of the local PE 650001:1.
Hope this helps,
Jose.
Hi Jose
That makes sense.
So what's the best practice in this kind of setup where I am simulating both sides of PEs sharing the same VRF are part of the same company?
I have a feeling that the RD value should be the same for them.
Thanks once again.
Mohit
It depends. Most common approach in SP is to assign the RD per PE, not per VPN. Simplest approach is to assign the RD per VPN. One of the advantages of using the RD per PE is that the same IPv4 prefix will be different (VPNv4) in the cloud and you could achieve load sharing as the RR will propagate both routes as in fact they are different. If you are using the same RD in the VPN, it will just advertise the best one. On the other hand, the memory consumption will be higher in the RD per PE case.
Hope this helps,
Jose.
