Basic Multicast
martinbuffleo
I have a Cisco 2811.
fa 0/0 is on 192.168.1.1
fa 0/1 is on 192.168.2.1
My VLC server is on 192.168.1.4 multicasting on 238.255.12.42
My VLC reciever is on 192.168.2.5.
I cannot get multicast working
Can any one advise me on the config please.
I have enable ip multicast routing in global mode.
Thanks in advance.
Martin.
17 Replies 17
Jon Marshall
Thanks in advance.
Martin.
Martin
1) check that you have set the TTL in VLC to > 1
2) under each interface -
   int fa0/0
   ip pim dense-mode
   int fa0/1
   ip pim dense-mode
If that works you may want to switch to use pim sparse-mode but first lets see if the above works.
Jon
francisco_1
Level 7
Level 7
Have you enable multicast on the router interfaces
ip pim sparse-mode
Give it a go.
see this link for more info http://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_basic_cfg_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1058990
Have added the
ip pim sparse-mode
Also tried dense mode with no joy
command to both interfaces still no joy
I'll read the guide you linked to.
Have added the
ip pim sparse-mode
deleted - a bit fast off the mark
Could you post -
1) "sh ip mroute"
2) "sh ip igmp groups"
also did you check the TTL setting in VLC ?
Jon
Thanks for your help on this Jon
VLC TTL is set to 30.
Router#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.250), 00:01:59/00:02:02, RP 0.0.0.0, flags: DC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    FastEthernet0/1, Forward/Dense, 00:01:59/00:01:58
    FastEthernet0/0, Forward/Dense, 00:01:59/00:00:00
(*, 238.255.12.42), 00:01:55/00:01:59, RP 0.0.0.0, flags: DC
    FastEthernet0/1, Forward/Dense, 00:01:56/00:01:58
    FastEthernet0/0, Forward/Dense, 00:01:56/00:00:00
(*, 239.255.12.44), 00:01:59/00:02:57, RP 0.0.0.0, flags: DC
    FastEthernet0/1, Forward/Dense, 00:01:59/00:02:03
(*, 224.0.1.40), 01:04:28/00:02:55, RP 0.0.0.0, flags: DCL
    FastEthernet0/0, Forward/Dense, 01:04:28/00:00:00
Router#show ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.255.255.250  FastEthernet0/1          01:04:27  00:02:50  192.168.1.5
239.255.255.250  FastEthernet0/0          01:04:36  00:02:51  192.168.2.4
238.255.12.42    FastEthernet0/0          00:52:00  00:02:53  192.168.2.4
238.255.12.42    FastEthernet0/1          00:52:40  00:02:52  192.168.1.5
239.255.12.44    FastEthernet0/0          01:02:04  00:02:47  192.168.2.4
239.255.12.44    FastEthernet0/1          01:04:28  00:02:54  192.168.1.5
224.0.1.40       FastEthernet0/0          01:04:36  00:02:47  192.168.2.1
Router#
Router#show run
Building configuration...
Current configuration : 1224 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
ip multicast-routing
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
ip pim dense-mode
duplex auto
speed auto
interface Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1
ip pim dense-mode
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager fax protocol cisco
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120
line vty 0 4
login
scheduler allocate 20000 1000
end
Martin
How are you determining it is not working - have you started up the vlc app on the client machine and tried to connect to the multicast stream ?
Jon
From the mroute output, I don't see the source listed in the table (S,G) and from the IGMP output you have 2 receivers that joined that group
Can you verify the server is actually sending packets toward the router?
What type of switch is the source attached to?
Can you verify pinging both ways?
I am testing it by run VLC client on the reciever.
I'm also running VLC client on the sender to confirm that VLC sender is running correctly.
Ping connectivity between the two laptop is good.
VLC sender(192.168.1.5) -------------- 2811-------------------VLC receiver(192.168.2.4)
                                       CAT5                CAT5
No other hardware involved.
I'm not familiar with VLC but if you are running the 'client app' not the 'server app' - you won't see any (S,G) in the mroute output.
You need to run a server application somewhere so clients can receive the stream.
It's the same up.
But one is sent to send the multicast stream and one is set to receive.
Do you have any scripts I can use to test. Rather than rely on Multicast?
Some VLC version has problem on the TTL setting; have to modify the setting to make it work. The one I know working fine is "VLC media player 0.8.6i", download that version and test it.
HTH,
Lei Tian
Martin,
I have tried your config in a lab to prove to your config is fine.
A single router with multiple interfaces
R1
eth0/0 1.1.1.1 - Sender behind this interface 1.1.1.2
eth0/1 2.2.2.1 - Receiver behind this interface 2.2.2.2
Used MulticastUDP App to test it. Used low TTL
Config
ip cef
ip multicast-routing!
interface Ethernet0/0
ip address 1.1.1.1 255.255.255.0
ip pim sparse-dense-mode
interface Ethernet0/1
ip address 2.2.2.1 255.255.255.0
Results - Multicast Address is 239.1.1.10
R1#sh ip mroute 239.1.1.10
(*, 239.1.1.10), 00:00:12/stopped, RP 0.0.0.0, flags: DC
    Ethernet0/1, Forward/Sparse-Dense, 00:00:08/00:00:00
(1.1.1.2, 239.1.1.10), 00:00:12/00:02:47, flags: T
  Incoming interface: Ethernet0/0, RPF nbr 0.0.0.0
R1#
R1#sh ip igmp groups 239.1.1.10
239.1.1.10       Ethernet0/1              00:00:37  00:02:51  2.2.2.2
R1#
Also see this regarding TTL issues with VLC http://forum.videolan.org/viewtopic.php?f=4&t=56351
Stream received across a single router.
Thanks for the heads up on the issue with VLC. Bloody ****,**** F&*! of rubbish
