Basic password encryption in router config
aksen1111
I am practicing basic RIP md5 authentication. Using the "service password-encryption" gives me as follows-
key chain cisco
key 2
key-string xxx
interface FastEthernet0/0
no ip address
shutdown
half-duplex
interface FastEthernet1/0
ip address 3.x.x.1 255.255.255.0
ip rip authentication mode md5
ip rip authentication key-chain cisco
half-duplex
router rip
version 2
network 3.0.0.0
line con 0
exec-timeout 0 0
password xxx
login
line aux 0
password xxx
login
line vty 0 4
password xxx
login
End
Seems like it encrypted the 'Key-string', however I was wondering is there a way to encrypt the cisco text for 'Key chain' too? I am just curious about how far the encryption is possible from here.
2 Accepted Solutions
spremkumar
Level 9
Level 9
hi
i dont think you can mask the key entered under the interface mode as we can do out with ospf where you can use either 0 or 7 as an option to enter the key.
regds
Edison Ortiz
The key chain string is locally significant so it doesn't provide any harm if viewed in clear text on the config.
spremkumar
Level 9
Level 9
hi
regds
Edison Ortiz
