Basic Routing Issue
Pete
I have 2 routers with a pix in the middle, the pix has an ip of 192.168.1.7 there is then a VPN connection to a remote site with the address range 192.168.254.0
I have added the route as shown below for the 192.168.254.0 network and I can ping Servers on the network from the Router but not from a client on the LAN (address range 192.168.0.0). I know this is basic but my tired mind is getting annoyed! Help!
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip ips sdm_ips_rule in
ip route-cache flow
duplex auto
speed auto
no mop enabled
ROUTES
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.254.0 255.255.255.0 192.168.1.7
ajagadee
What are the Access-List Entries for "ip access-group 102 in" on Fa0/0. Are you allowing traffic from 192.168.0.x to go to 192.168.254.x.
And can you post the full configuration. Make sure that you remove all sensitive information, like passwords and public IP's before posting the configuration.
Arul
mheusinger
Level 10
Level 10
I would check for a couple of things more:
Is there a route pointing back to 192.168.0.0/24 ? It should be available on all routers/firewalls inbetween the client and servers. To check this, use an extended ping with source IP 192.168.0.254. Per default a router sets the outgoing interface IP as source IP in ICMP packets. So 192.168.1.0/24 might be known to the rest of your network 192.168.0.0/24 might be not (and thus follow the default route into the internet, where it is discarded.).
Second I would check wether the desired traffic is allowed in the VPN tunnel from both sides. My guess however is, that one or two static routes to 192.168.0.0/24 are missing here and there ;-)
Hope this helps! Please rate all posts.
Regards, Martin
Could you please provide the tracert from your PC ? I suspect there is default GW issue or static for return traffic issue.
And please try to ping from the router but use FE0/0 & FE0/1 as the source interface and test again. e.g. Don't type IP address after the "ping" command and hit enter then follow each row to enter the destination IP & source IP.
Hope this helps.
It sounds the problem might be in Access list. Can u post the Access List to troubleshoot?
