Best Design for Multicast
zaqtivi
Hi Everyone,
What could you suggest when we always have a PIM neighbor always going down ? Router has no issues, but the ISP is. Kindly advise. Thanks!
Sep 21 23:56:06.176: %PIM-5-NBRCHG: neighbor <IP> DOWN on interface GigabitEthernet0/0 non DR
Sep 21 23:56:21.767: %PIM-5-NBRCHG: neighbor <IP> UP on interface GigabitEthernet0/0
Sep 25 15:22:47.694: %PIM-5-NBRCHG: neighbor <IP> DOWN on interface GigabitEthernet0/0 non DR
Sep 25 15:23:03.350: %PIM-5-NBRCHG: neighbor <IP> UP on interface GigabitEthernet0/0
Router#sh ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
P - Proxy Capable, S - State Refresh Capable, G - GenID Capable,
L - DR Load-balancing Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
<IP> GigabitEthernet0/0 01:14:59/00:01:30 v2 1 / G
johnd2310
Level 8
Level 8
Is the routing going down as well or is it just PIM?
John
**Please rate posts you find helpful**
Hi johnd2310,
Thank you for your response. It is just PIM that is going down.
Can you suggest what else to check ? Or where to go from here ? Thanks!
