best dual wan routers for small branch office (5 persons)
jomo frank
Hello Expert,
I have 4 very small branch (5 person) each and would be grateful if anyone can recommend four
4 FastEthernet interfaces or dual wan interface to cater for business continuity
See Table 1 in this link to choose your router that support your internet media type http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78-519930.html
Use CEF for load-balancing WAN links.
paulstone80
Level 3
Level 3
For a SOHO environment I would recommend the Cisco 800 series.
Sent from Cisco Technical Support Android App
HTH Paul ****Please rate useful posts****
hello expert,
Thanks for the response.
I did some checking and the 881 model looks like the one that will satisfy all my requirements, but i have one question
thses routers are equipt with (1) wan interface and all review states it can do wan failover.
How is possible using 1 wan interface.
