ip dhcp snooping statistics
Arthur Kant
We are a service provider with an extremely large layer2 for DHCP in some areas.  I just enabled dhcp snooping on this vlan with:
ip dhcp snooping vlan 8
no ip dhcp snooping information option
no ip dhcp snooping verify mac-address
ip dhcp snooping
DHCP still appears to be flowing correctly but I am curious about the statistics Im seeing:
Packets Forwarded                                     = 26739
Packets Dropped                                       = 35498
Packets Dropped From untrusted ports                  = 45
What is causing dropped packets?  I could understand if bad foo was dropped from the untrusted ports but Im not sure of the other.
thanks!
Jeff Van Houten
Level 5
Level 5
You do have some ports identified as trusted, correct?
Have you tried the "detail" option of the "show ip dhcp snooping statistics" command?
Packets Dropped Because
IDB not known                                       = 0
Queue full                                          = 0
Interface is in errdisabled                         = 0
Rate limit exceeded                                 = 0
Received on untrusted ports                         = 0
Nonzero giaddr                                      = 0
Source mac not equal to chaddr                      = 0
No binding entry                                    = 0
Insertion of opt82 fail                             = 0
Unknown packet                                      = 0
Interface Down                                      = 0
Unknown output interface                            = 0
Misdirected Packets                                 = 0
Packets with Invalid Size                           = 0
Packets with Invalid Option                         = 0
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_58_se/command/reference/cli2.html#wp11913684
Best Regards
Rolf
