best solution
aminmeh
   What is the  Best slotion and configure for above pic?
6 Replies 6
Georg Pauwen
what are you after ? What part of the configuration is a problem ?
Left site, I have problem configure load balance between firewalls and routers  .
balaji.bandi
Provide more information, what is the devices in the network, what i IOS code running on it, what is existing configuration ?
BB
both firewall are cluster active active,according to load and latency
links between two site trafic share them
balaji.bandi
still, that information is not good enough for us to understand :
1. between site how many links you have?
2. you would to Load balance for what?
3. Active / Active in cisco world is Multi context? ( or what FW is this ?)
4. at this stage we can only guess and give a high-level suggestion,
   you need to HSRP / with IP SLA to Load share on 1 router, if that fails it will be moved to another router.
   if you have 2 Link, you can do PBR based on the source address.
but i am sure with this you not going to solve the issue that you trying to do. ( since we are only assuming here)
Let me try to help with the last request - kindly provide more information - in detailed.
BB
i can use for polcy route and load sharing between to site use BGP?
