Best way to subnet small site
CiscoBrownBelt
Level 6
Level 6
Let's say I have to use the 192.168.X.X address space for numerous sites.
I would like to correspond the 3rd octet to the site but still separate different traffic for the site - maybe separate for 4-5 different teams/departments. I don't want things to get out of flow or have problems let's say if these sites began to expand or double in size.
Does  let's say using /28, then /26, etc. subnets sound like the best approach if I must use 192.168?
5 Replies 5
Hi CiscoBlueBelt,
It all depends on the machines you have in each department and chances of expansion. I would recommend using 192.168.x.x/23 for the bigger site and 192.168.x.x/24 for smaller sites. Then equally divide the subnet further department wise.
For example, use 192.168.0.0/23 and you have four departments at this site then divide the subnet as follow:
192.168.0.0/25
192.168.0.128/25
192.168.1.0/25
192.168.1.128/25
I think 126 usable IP's are enough for each department.
Spooster IT Services Team
Basically, as of now I would like to correspond the 3 Octet in the 192.168.X to the site. This would leave me to only be able to break up the 4th octect correct?
Correct.
mlund
Level 7
Level 7
I see You have stated you must use 192.168 this is private space. Is there a reason you can't use 10.x..x.x instead?
Because with 10 space you can do 10.<department>.<site>.<user>
/Mikael
Yes, lab assignment is to do it with 192.168 unfortunately.
