BFD - EIGRP - Tunnel Endpoint Liveness detection
Robert.Dahlem_2
I would like to use BFD for Tunnel Endpoint Liveness detection (as mentioned in BFD white papers)
Router A:
interface GigabitEthernet0/0
  ip vrf forwarding INNER
  ip address 1.1.1.1 255.255.255.252
  bfd interval 50 min_rx 50 multiplier 3
interface Loopback1
  ip address 2.2.2.1 255.255.255.255
interface Tunnel1
  ip vrf forwarding OUTER
  ip address 3.3.3.1 255.255.255.2
  tunnel source 2.2.2.1
  tunnel destination 2.2.2.2
  tunnel mode ipsec ipv4
  tunnel protection ipsec profile WHATEVER
  tunnel vrf INNER
router eigrp 1
  address-family ipv4 vrf INNER autonomous-system 2
    bfd all-interfaces
    network 1.1.1.0 0.0.0.3
    network 2.2.2.0 0.0.0.255
  address-family ipv4 vrf OUTER autonomous-system 3
    network 3.3.3.0 0.0.0.3
Router B:
  ip address 1.1.1.2 255.255.255.252
interface Loopback1
  ip address 2.2.2.2 255.255.255.255
interface Tunnel1
  ip address 3.3.3.2 255.255.255.2
  tunnel source 2.2.2.2
  tunnel destination 2.2.2.1
  tunnel vrf INNER
router eigrp 1
    bfd all-interfaces
Routers A and B are connected via their respective interfaces Gi0/0. Network 1.1.1.0/30 comes up, EIGRP neighborship between 1.1.1.1 and 1.1.1.2 in VRF INNER is established and both sides learn about 2.2.2.1 and 2.2.2.2 respectively. This means the tunnel endpoints can be reached and Tunnel1 comes up, hence EIGRP neighborship between 3.3.3.1 and 3.3.3.2 in VRF OUTER ist established.
Now when I disconnect Gi0/0, BFD kicks in and tears down the EIGRP neighborship in VRF INNER almost instantly. This makes 2.2.2.2 unreachable from Router A, so I would expect Tunnel1 to go down the same moment because the tunnel endpoint can no longer be reached. Instead, the tunnel goes down not before 15 or 20 seconds have elapsed and likewise the EIGRP neighborship in VRF OUTER times out.
What I would like to see: connection loss between Router A and B tears down EIGRP neighborship in VRF OUTER in the sub second range. Can this be done?
Robert
Mohamed Sobair
Level 7
Level 7
Robert,
This symptoms can be resolved with (Tunnel Keepalive). You just need to add a Keepalive to the Tunnel interface and you should see faster notification.
In the Tunnel Interface add the following:
Interface Tunnel1
Keepalive 1 3
Mohamed
Robert,
Ok, So the Keepalive is not supported with VRF.
Now, your Only option for a rapid convergence would be to use IP SLA. you can track the tunnel Destination from both ends which would achieve what you are looking for.
http://www.cisco.com/en/US/docs/ios/ipsla/command/reference/sla_05.html
Mohamed
