BFD interface configuration is not working on IOS 17.12.4A on C85xx
mtjandra
hi all,
Trying to configure BFD on a router interface on C8500-12X running IOS 17.12.4a, but it seemed like the command is gone on this IOS version.
router(config)#int ten 0/0/2
router(config-if)#bfd ?
% Unrecognized command
Anyone know anything about it?
thanks
You may have to have the correct license to use that feature. Can you show which license you are using? You might need the "network-advantage" one.
-David
-David
thanks David.. this is the one indeed.
@mtjandra
In modern IOS XE versions, BFD is often enabledper routing protocol / OSPF-BGP etc...
router ospf 1
bfd all-interfaces ! Enable BFD for all OSPF-enabled interfaces
! OR per-interface:
interface TenGigabitEthernet0/0/2
ip ospf bfd ! Enable BFD for OSPF on this specific interface
Thanks!
mtjandra
Thank you.. irouting configuration was actually there..
but found the issue was DNA-advantage license needed to be activated.
