BFD on VDSL connections?
3rdman
Hi All.
I'm trying to get BFD enabled for VDSL connection, currently using Cisco 8300 with NIM-VAB-A card where we're terminated a VDSL connection.
I have tried the following but the router doesn't see any BFD interfaces set up??
interface Ethernet0/1/0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
bfd interval 300 min_rx 300 multiplier 3
end
Is this the correct way of performing this task? I already specified the neighbor [ip] fall-over bfd command under my BGP configuration. Am I missing something here?
Thanks.
balaji.bandi
what is the issue here ( I have not used using VDSL, but have good deployment over Fibre and BGP)
what are you looking to achieve here with BGP or BFD ?
BB
that correct from my view
you use BFD to detect Peer down (since the direct connect can not detect it).
