BFD question
I have a cisco 2 ASR1006 routers that are running a BGP session on loopbacks. The loopbacks can reach each other via EIGRP configured on four links. My two routers are running at 50% CPU utilization. Will the routers be able to handle BFD if I am to apply  it EIGRP and BGP sessions
2 Accepted Solutions
M02@rt37
Hello @charles-mashambaaa
Configure moderate BFD timers to reduce CPU load. For example, set a detection multiplier of 3 with an interval of 300ms to strike a balance between failure detection speed and resource usage.
Start by enabling BFD on a limited number of sessions with moderate timers and closely monitor the CPU usage. Adjust configurations as needed to prevent performance degradation.
Best regards
Use feature bfd offload if your router supports it
MHM
M02@rt37
Best regards
MHM
