Bookmark
Subscribe
504
BFD Support on 6500 / high-end switch
craig_baum
Hello all,
I'm putting together an expansion for a customers network and need a high density 10/100/1000 switch-type aggregation with link agg etc and basic OSPF routing.
The problem is that the GE backhaul links are over a transmission network that does not support link-loss forwarding and so need to run BFD across it. Looking at the data sheets, the 6500 is ideal for port density/carrier class redundancy but appears the sup module does not support BFD. Is this true? Any other options or do I need to cost in a 76xx chassis with the required 65xx switch blades?
Cheers,
Craig.
vladrac-ccna
Level 5
Level 5
hello Craig,
Checking cisco feature navigator for:
BIDIRECTIONAL FORWARDING DETECTION
I could see it available for plataform CAT6000, is this your case?
HTH,
if it does, please rate this post.
Vlad
