BGP Address family - Cannot see in running config
HI,
I am trying to create a multiple VRF networ using vrf lite and BGP (we dont have the ability to run an MPLS backbone)
I have Site A with Corp traffic not in a vrf (this is in the standard routing table) and Public traffic in its own VRF (Public). I am using 802.1q tags onto the WAN to maintan the segrigation corp has a tag of 100 and public has a tag of 911.
I have created BGP peerings between Site A and the Route Reflector on the non-vrf Corp WAN Link (tagged with a tag of .100) I have also created a ipv4 address family vrf PUBLIC on both the route reflector and the Site A end and created peerings in this address family for these addresses (tagged with a 911)
All peerings have come up but I cannot see the PUBLIC address family config in the show-running config output
For address family: IPv4 Unicast
BGP router identifier 172.17.1.10, local AS number 65000
BGP table version is 1, main routing table version 1
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
172.17.1.3      4 65000      55      55        1    0    0 00:52:44        0
For address family: VPNv4 Unicast
172.17.5.3      4 65000      54      54        1    0    0 00:50:48        0
output from show running config:-
 speed auto
router bgp 65000
 no synchronization
 bgp log-neighbor-changes
 neighbor 172.17.1.3 remote-as 65000
 no auto-summary
ip forward-protocol nd
I a bit of a newbie at VRF's with BGP so any help would be apprechiated.
Hello
router  bgp xxx
bgp upgrade-cli
Note:--it isnt an intrusive change but once you upgrade you cannot revert it
res
Paul
Kind Regards
Paul
