BGP Advertisements
Simon Young
I have an issue where I am migrating from one location to another.
I want to advertise the same prefix from two seperate sites but I want to advertise individual unicast addresses from separate sites
This is where I am at, any help would be much appreciated as I can't seem to get this to work. All the traffic is just routed to one site. I do have the other site as backup but not as the primary for individual routes
ip access-list standard Denied-SiteA
permit host 192.168.1.1
permit host 192.168.1.2
ip access-list standard Allowed-SiteA
permit 192.168.1.0 0.0.0.255
ip access-list standard Allowed-SiteB
permit any
route-map SiteA permit 10
match ip address Denied-SiteA
set as-path prepend 11111 11111
route-map SiteA permit 20
match ip address Allowed-SiteA
route-map SiteA permit 30
match ip address SiteB
router bgp xxxxx
neighbor xxxx route-map SiteA out
end
permit any
route-map SiteB permit 10
set as-path prepend 22222
route-map SiteB permit 20
set as-path prepend 22222 22222
route-map SiteB permit 30
router bgp xxxxx
neighbor xxxx route-map SiteB out
end
Hi Simon,
You should still be able to do the following:
advertise from site A:
192.168.1.0/24
192.168.1.100/32
192.168.1.105/32
Advertise from site B:
192.168.1.0/24
192.168.1.1/32
192.168.1.2/32
And prepend only on 192.168.1.0/24 depending on which site you want to prefer.
Hope this helps
8 Replies 8
Harold Ritter
Hi Simon,
Can you please more information. Are these site connected to the Internet or a private network. If they are connected to the Internet, the /32 prefixes will likely not make it beyond your ISP because of prefix filtering on the Internet. In this case only the /24 would be seen on the Internet.
Its a private MPLS cloud. I am advertising the routes to other sites within the same cloud.
Thanks for the info. I see in the route-map that you advertise 192.168.1.1/32 and 192.168.1.2/32 but I do not see 192.168.100/32 and 192.168.1.105/32 being advertised on the other side. Can you please provide the complete bgp config from both side.
I don't have a complete BGP configuration to post as its a production environment, that I have replicated in my lab and I have modified the IP address to post here
I was hoping that 192.168.1.100 and 105 would be caught under permit 192.168.1.0 0.0.0.255 (i put them in purely to illustrate different IPs and can see that might be a bit confusing)
I was hoping to have site A as the primary path for the 192.168.1.x subnet (except for 192.168.1.1 and .2). Everything else including 192.168.1.1 and .2 via Site B
LocationPrimary Secondary
192.168.1.1Site Bprepended 22222prepended 11111 11111
192.168.1.2Site Bprepended 22222prepended 11111 11111
192.168.3-254Site Aprepended 11111prepended 22222 22222
All other RoutesSite Bprepended 22222prepended 11111 11111
I have a backup path as the two data centres are linked. Each has dual MPLS but as an absolute fail over there is also a link between them.
I can't seem to fine tune my configuration so that individual addresses are removed from the main /24. Currently I go to one site only
Thanks for your replies.
Hi Simon,
I would recommend to just announce 192.168.1.0/24 from site A and just the more specific (192.168.1.1/32 and 192.168.1.2/32) from site B. This way site A would attract all traffic to 192.168.1.0/24 except for .1 and .2 and you would not need to play with the prepend at all.
Hope this help
I had thought about doing that with aggregate addressing but I was hoping for a way of not having to change the network statements
I want to scale this up to many prefixes, not just a single one.
Also I need a backup route to the second site, in case the primary fails, thats why I want the pre-pend
Either way thanks for responding, I appreciate the feedback
Hi Simon,
192.168.1.0/24
192.168.1.100/32
192.168.1.105/32
192.168.1.0/24
192.168.1.1/32
192.168.1.2/32
Hope this helps
as Harold said, it should be possible to configure what you want.
But it's difficult to say what's wrongin your config without having it available.
So just guessing:
Are there the host routes (static I suppose) configured on your routers?
If not present in RIB, BGP can't advertise them.
