Can't ping to up Tunnel
Mero Cisco
I have created the tunnel interface on cisco 1841 router. The tunnel is up but can't ping to it's interface ip, the ping drops.
Please have a look at the following output and give me some suggestions,
Thanks for your cooperation in advance.
R1#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Tunnel10                   10.10.10.1    YES manual up                    up
R1#sho int tunn10
Tunnel10 is up, line protocol is up
  Hardware is Tunnel
  Description: Connection to Branchess
  Internet address is 10.10.10.1/24
  MTU 1514 bytes, BW 9 Kbit, DLY 10000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.10.18.1 (FastEthernet0/1), destination UNKNOWN
  Tunnel protocol/transport multi-GRE/IP, key 0x987756, sequencing disabled
  Checksumming of packets disabled,  fast tunneling enabled
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
Hello
Is the tunnel destination specified and reachable?
Enable keepalive on the tunnel and see if it still stays up
int tun 10
keep 5
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
johnlloyd_13
Level 9
Level 9
hi,
your tunnel and source ip are overlapping. kindly re-assign with different subnets.
John
If the tunnel source is
and the tunnel address is
then I do not see the overlap that you do.
I believe that it would be helpful if the original poster would give us the details of how the tunnel is configured. I am very interested in this line of output and would like to see the configuration behind it
Rick
Rick
Dear All,
Please look at the following configuration. When I shift the following commands to other router I can ping to tunnel interface but on this router I am not being able to ping
crypto isakmp policy 10
encr aes
authentication pre-share
crypto isakmp key XXXX address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 20 3
crypto ipsec transform-set DMVPN esp-aes esp-sha-hmac
mode transport
crypto ipsec profile dmvpnprofile
set transform-set DMVPN
interface Tunnel10
description Connection of HO
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip mtu 1436
ip nhrp authentication XXXX
ip nhrp map multicast dynamic
ip nhrp network-id 6666
ip nhrp holdtime 600
ip ospf network broadcast
ip ospf priority 3
delay 1000
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 67876
