BGP advertisements
SD-Human
Hi All,
I'm trying to control BGP advertisements and I have two questions about the different possibilities.
a) Is it any way to control the number of prefix to advertise to a neighbor by number.
b) Can I see the limit of prefixese stablished by my neighbor (via maximun-prefix) from my device, for example taking a look on debugs or something like that.
This is a question for IOS and ASR as well.
Thanks!
Richard Burts
I believe that the behavior of IOS and of ASR are similar.
a) while you can control the number of prefixes that are received from a neighbor I do not believe that you can control by number the number of prefixes that you advertise to a neighbor.
b) I do not know of a way to see the limit to number of prefixes established by a neighbor.
Rick
Rick
Hi Rick!
Bad Luck...thank you anyway.
