Cisco 4331 router - No internet access
HADES2001
Dear readers,
I am running into an issue, we are replacing a draytek router model 2130 with a Cisco 4331 router.
The internal network is working fine but I cant seem to get the internet working.
I tried searching the forums and looked up multiple Cisco router wan basic setup guides but no success yet.
The details that I know.
Cisco port G0/0/0 IP 5.83.2.162/30 *EDIT was /32 but should be /30
Cisco port G0/0/1 IP 192.168.100.50/24 that is connected to a 48 port switch.
DNS servers of the webprovider are 178.217.80.81 and 178.217.81.80
I copied the settings of from the draytek, our provider says that is all and that there are no hidden settings that are required. (aka usernames/passwords)
When i use the webinterface to do a WAN connection test I get a green checkmark on everything except the ping to 8.8.8.8
I have added in a text file the output of "show ip route" and "show conf" since in similar issues that are the most requested outputs at the start.
Does anyone maybe see what I am overlooking?
Thank you all in advance for your time
Will you please change your default route configuration as follows:
"ip route 0.0.0.0 0.0.0.0 5.83.2.161"
Best regards,
Antonin
12 Replies 12
you say that your provider has given you IP 5.83.2.162/32, however, you have configured /30.
Try:
interface GigabitEthernet0/0/0
ip address 5.83.2.162 255.255.255.254
or
ip address 5.83.2.162 255.255.255.255
Also,
add the lines i bold below to your config:
interface GigabitEthernet0/0/1.11
encapsulation dot1Q 11
ip address 192.168.50.30 255.255.255.224
ip nat inside
ip helper-address 192.168.100.2
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 192.168.50.0 0.0.0.31
And also:
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
Thanks for the quick response,
I did forget to mention one important part, we will start working in the future with vlans that will come on 192.168.50.*, but that isnt in use yet our entire network at this moment is on 192.168.100.*/24
The 5.83.2.162/30 is copied from the draytek, I added a screenshot of the its WAN configuration page.
I will do the changes you mentioned straight away, sadly because of work hours the draytek is connected again and cant test.
Will come back to you as soon as possible
EDIT: just noticed the mistake in the opening post, edited it sorry for the confusion
Dear Georg,
I have changed the settings as recommended but still cant ping 8.8.8.8 from the router, and cant ping 5.83.2.162 from the outside.
Added the new show conf file
Is there maybe anything that you still recommend?
Thank you for all your help.
Hi HADES2001,
Are you able to ping default gateway(5.83.2.161) from your router?
If not, then check the interface status like speed and duplex.
Spooster IT Services Team
Best regards,
Antonin
Thank you all so much for the help,
I added "ip route 0.0.0.0 0.0.0.0 5.83.2.161"
also removed the "spanning-tree portfast trunk" on port g0/0/0.
The webinterface wont let me do the WAN test anymore because it keeps saying there is no port configured as WAN anymore.
But besides that internet is working. (the port forwards arent working yet so our internal applications cant be accessed from the outside but since we now have internet access and the IP phones are working I can easily sit down for that without having short time frames)
again, thank you all for the assistance, hope i gave the helpfull stars away in the proper way new to these forums
take the 'spanning-tree portfast trunk' off the outside interface and remove the route map. So the config should look like this:
Using 3270 out of 33554432 bytes
! Last configuration change at 11:25:51 UTC Wed Mar 28 2018
! NVRAM config last updated at 11:25:55 UTC Wed Mar 28 2018
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname MandAR1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging console *removed*
enable secret 5 $1$JXg5$TVFWarnHFk0LqxkZzggf50
enable password *removed*
no aaa new-model
ip name-server 178.217.80.81 178.217.81.80
subscriber templating
crypto pki trustpoint TP-self-signed-2671645268
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2671645268
revocation-check none
rsakeypair TP-self-signed-2671645268
crypto pki certificate chain TP-self-signed-2671645268
license udi pid ISR4331/K9 sn FDO21420XP4
diagnostic bootup level minimal
username administrator privilege 15 secret 9 $9$4/AI2/AJ1lMM3U$GBG83ziWuEWKIfGXiYhuGADgZtLSC9maMB8LDUnjXZc
username Steven privilege 15 secret 9 $9$4/.L2lIH3lIJ2k$UftXmhQUeCwOhNhCHAIhw4hmm3hJN3aFJQbFT35bp66
redundancy
mode none
ip address 5.83.2.162 255.255.255.252
ip nat outside
negotiation auto
ip address 192.168.100.50 255.255.255.0
ip nat inside
negotiation auto
ip nat inside
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat inside source static tcp 192.168.100.8 80 5.83.2.162 80 extendable
ip nat inside source static tcp 192.168.100.8 443 5.83.2.162 443 extendable
ip nat inside source static tcp 192.168.100.8 8084 5.83.2.162 8084 extendable
ip nat inside source static tcp 192.168.100.4 9093 5.83.2.162 9093 extendable
ip nat inside source static tcp 192.168.100.4 9094 5.83.2.162 9094 extendable
ip nat inside source static udp 192.168.100.4 9094 5.83.2.162 9094 extendable
ip forward-protocol nd
ip http server
ip http port 51283
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password *removed*
login
length 0
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
I see this in an earlier post from the original poster
if the router can not ping an Internet IP address then that is the first problem that we need to solve. Any of the other suggestions about the config should wait till this is solved.
Having suggested that other topics should wait I feel that I must say that I agree with Antonin that the default route pointing just to Gig0/0/0 may be problematic. And that is not what the Draytek was using. A default route specifying the next hop address (or perhaps both outbound interface and next hop address) is better and is what the Draytek was using.
Rick
Rick
Having read through the thread again and thinking about the issue I would suggest that the first step should be to find out if the router can ping 5.83.2.161.
If not then I would ask for the original poster to post the output of the command show ip interface brief
Rick
Rick
Dont worry I am still here, sadly I am stuck on very short time frames because the employees require internet access.
setting alarm extra early to test all the help just posted.
internet access is the primary target, all other things are on hold. (Project managers tend to forget that 9 women cant bear a child in 1 months)
i truelly appreciate all the help from everyone here and will let everyone know tomorrow what the results are.
