bgp advertising default route in mutihomed network
Athiqur Rahman
I have Cisco 7200vxr doing BGP with 2 directly connected ISP's over ethernet. I am receiving default routes only, and have added a higher weight to my routes learned from my primary ISP. below is my configuration (ip addresses changed of course)
router bgp 100
no synchronization
bgp router-id x.x.x.x
bgp log-neighbor-changes
network 100.100.64.0 mask 255.255.254.0
network 100.100.71.0
network 100.100.78.0 mask 255.255.254.0
neighbor <ISP_A-IP> remote-as 200
  neighbor <ISP_A-IP> weight 175
neighbor <ISP_B-IP> remote-as 300
  neighbor <ISP_B-IP> weight 150
auto-summary
Advertising my rotues to the primary ISP is fine
7206vxr.rb#sh ip bgp neighbors <ISP_A-IP> advertised-routes
BGP table version is 7, local router ID is x.x.x.x
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 100.100.64.0/23   0.0.0.0                  0         32768 i
*> 100.100.71.0      100.100.64.57             0         32768 i
*> 100.100.78.0   0.0.0.0                  0         32768 i
Total number of prefixes 3
However, advertisements to the secondary ISP inlcludes the defautl route learned from the primary
7206vxr.rb#sh ip bgp neighbors <ISP_B-IP> advertised-routes
*> 0.0.0.0          <ISP_A-IP>
Question is is that normal behavior? Should I not just only be advertising just the networks that i specified in my configuration?
milan.kulik
Level 10
Level 10
yes, this is normal.
By default, a BGP router is advertising prefixes received from one eBGP neighbor to other BGP neighbors.
If you want to prevent this behavior, you need to configure something like this:
ip as-path access-list 1 permit ^$
router bgp 100
neighbor remote-as 200 route-map advert out
neighbor remote-as 300 route-map advert out
route-map  advert permit 10
match as-path 1
This way you will advertise only prefixes originated in your own AS.
HTH,
Milan
Hi Athiqur,
It is highly recommended you have as path filters on your routers when peering with different AS's. Otherwise, there is a potential that your AS might become the transit AS .e ISP B will use your AS to get to ISPA (not that it happens often but there is potential if the peering config on the ISP end is stuffedup). Imagine that the ISP-B is not pushing out the default route to you. It will then learn the default route via your AS and start forwarding traffic towards your AS...just as an example..
HTH,
Kishore
Thanks guys, you've been a great help
