base conf. for 1721
alessandro_t
Hi all,
  I bought a cisco 1721, and since yesterday I have an shdsl. The 1721 has only a WIC-1T, with the V35 cable.
The telecom company gave me a simple "template" configuration, where I had to set the password and the public ip (see below).
Note that I'm "new" in cisco IOS world, so -obviously- it doesn't work. I check if it is working by "pinging" some internet ip.
The V35 is connected, the lan ethernet no.
I need only a simple working configuration, in order check the line. Then I have all the time I want to study IOS.
Actually I'm not able to ping anything (Success rate is 0 percent (0/5)) , but it seems to me that traceroute is working:
# trace 170.149.173.130
Tracing the route to 170.149.173.130
  1 213.21.129.54 8 msec 8 msec 12 msec
  2 213.21.130.2 12 msec 8 msec 12 msec
  3  *  *  *
Thanks for your help
The output of  "show interfaces" is the following (note the two "down" virtual interfaces; is it normal?):
FastEthernet0 is up, line protocol is down
   Internet address is <Pubblic Subnet IP>/<Subnet Public Mask CIDR>
Serial0 is up, line protocol is up
Serial0.1 is up, line protocol is up
    Internet address is X.X.X.X/32   (<= this is not my configuration, it should be assigned by PPP)
Virtual-Access2 is down, line protocol is down
Virtual-Template1 is down, line protocol is down
# running-config:
Building configuration...
Current configuration : 989 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface FastEthernet0
description connected to EthernetLAN
ip address <first ip of the public subnet> <Pubblic Subnet Mask>
speed auto
interface Serial0
no ip address
encapsulation frame-relay IETF
no fair-queue
interface Serial0.1 point-to-point
description Connessione SHDSL
no cdp enable
frame-relay interface-dlci 20 ppp Virtual-Template1
interface Virtual-Template1
ip address negotiated
ppp chap hostname <CODE>
ppp chap password 0 <PASSWD>
ppp pap sent-username <CODE> password 0 <PASSWD>
ppp ipcp route default
ip classless
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
lgijssel
Level 9
Level 9
At least you need the following:
ip route 0.0.0.0 0.0.0.0 interface Serial0.1
Goodluck!
Leo
The following configuration works better
I can reach the router from internet with telnet!
But I'm not able to ping anything from the router.. could it be a nat problem?
No lan client is able to connect to internet
#show run
Current configuration : 1353 bytes
version 12.4
service tcp-keepalives-in
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
interface Loopback0
description PUBBLIC LAN
ip address 255.255.255.248
description PRIVATE LAN
ip address 192.168.9.1 255.255.255.0
ip nat inside
ip route-cache flow
no ip mroute-cache
speed auto
full-duplex
interface Serial0
description Frame-Relay Net
bandwidth 2048
no ip address
no fair-queue
description Connessione SHDSL MC-link
ip nat outside
no cdp enable
ppp chap hostname
ppp chap password 0
ppp pap sent-username password 0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0.1
no ip http server
ip nat inside source list 1 interface Loopback0 overload
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
[the following is relevant the first configuration, on the top of the thread]
The "ping" didn't work because in this particular configuration I have to use the extended command:
Router#ping
Protocol [ip]:
Target IP address: 8.8.8.8
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: FastEthernet0
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/50/52 ms
Pc clients works by setting as default gateway the FastEthernet0 public ip, and as ip another public ip.
