BGP aggregate address vs IP route null0
davinci
these routers are direclty connected via point to point connection.  When I try summarization, only ip route x.x.x.x x.x.x.x null0 with network statement works for me.  When I use the aggregate address command I dont see summary route in route table.  Why?
R3#sh run | s bgp
router bgp 65011
no synchronization
bgp log-neighbor-changes
network 172.16.0.0 mask 255.240.0.0
network 192.168.0.0 mask 255.255.0.0
aggregate-address 176.16.0.0 255.240.0.0
aggregate-address 192.168.0.0 255.255.0.0
neighbor 10.254.28.108 remote-as 65011
neighbor 10.254.28.108 update-source FastEthernet0/0
neighbor 10.254.28.108 next-hop-self
no auto-summary
R4#sh run | s bgp
router bgp 65011
no synchronization
neighbor 10.254.28.107 remote-as 65011
neighbor 10.254.28.107 update-source FastEthernet0/0
neighbor 10.254.28.107 next-hop-self
no auto-summary
R4#sh version
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 21:36 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
R4 uptime is 22 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3725 (R7000) processor (revision 0.1) with 249856K/12288K bytes of memory.
Processor board ID FTX0945W0MY
R7000 CPU at 240MHz, Implementation 39, Rev 2.1, 256KB L2, 512KB L3 Cache
4 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
55K bytes of NVRAM.
6 Replies 6
Giuseppe Larosa
Hello davinci,
for aggregate-address to work in BGP at least one component route must be in the BGP table.
So if you would like to send an aggregate for IPv4 prefix 192.168.0.0 255.255.0.0 = 192.168.0.0./16 at least one component route like 192.168.1.0/24 should be present in the BGP table by any means either learned by another BGP peer or locally injected using a network command or a redistribution from other protocol (connected, static route or dynamic route from an IGP like OSPF or EIGRP).
To be noted the network command in BGP requires exact match when using no auto-summary (that is now the default).
This means that for advertising component network 192.168.1.0/24 that is a connected route for example you need under router bgp the command
network 192.168.1.0 255.255.255.0
! actually the mask could be omitted because 192.168.1.0/24 is  a Class C Major network.
So in order to make the aggregate-address to work you need to add specific network statements for one or more component routes.
It is not enough to have the more specific component route in the IP routing table only. You need to have them in the BGP table too.
On the other hand a static route to null0 is the oldest method to create an aggregate address that is always on regardless of existance of any component in the BGP table, and it requires a matching network statement with same subnet mask as you have configured.
However, note that for all IP addresses not belonging to a known component route packets with this destination will be silently dropped as this is what the nulll0 is supposed to be a waste bin.
The aggregate-address when not using the summary-only allows advertisement of the aggregate and all alive component routes.
Hope to help
Giuseppe
thanks, I will have to try that in my lab.
"On the other hand a static route to null0 is the oldest method to create an aggregate address that is always on regardless of existance of any component in the BGP table, and it requires a matching network statement with same subnet mask as you have configured.
However, note that for all IP addresses not belonging to a known component route packets with this destination will be silently dropped as this is what the nulll0 is supposed to be a waste bin."
so in other words, if i have 192.168.10.0/24 and 192.168.11.0/24 in my IP route table and I configure 192.168.0.0/16 as summary/aggregate route but someone send traffic to 192.168.13.1 then that traffic is dropped via null0?  I believe that is what you're saying here?
Hello davinci,
yes your understanding is correct but only when you use the static route to null0 method not with the aggregate-address command
Yes of course.
Hope to help
Giuseppe
yasir.ilyas
hi,
I know its  very  old thread. I am in similar  situation where  i havea  static null0  route and  i  advertising  that  with aggregate  address  command like below and  not  seeing aggregate.
ip route 100.65.240.0/22 Null0
router bgp 4200070001
address-family ipv4 unicast
aggregate-address 100.65.240.0/22 summary-only
whats  wrong  here doing this way?
You have not told us much about your environment and that makes it difficult to give good advice. But based on what is in your post I have these comments:
- you have both a static route to null0 and an aggregate-address command for a network. Use one or the other but not both.
- if you use a static route to null0 then you should see the aggregated address in your routing table. And if you have a correct network statement in your bgp config then the network should be advertised to your neighbors.
- if you use aggregate-address you would not see the aggregated address in your local routing table. If it is properly configured, and if at least one component route is present in your routing table then the aggregate is advertised to your neighbor. You can use show ip bgp neighbor <address> advertised to show the aggregated address.
- if you use a static route to null0 then the aggregate address will always be present in your routing table. Even if you no longer can reach that network it will still be advertised to your neighbors (because it is present in the ip routing table). If you use aggregate-address and that network is no longer reachable (no component routes are in your ip routing table) then the aggregate is NOT advertised to your neighbors.
Rick
Hi @yasir.ilyas ,
If you want to originate a route in bgp from a static route to null0 (or from any other route in the routing table (RIB)), you need to use the network statement (network 100.65.240.0/22). The network statement mask needs to match the mask in the RIB. It will not work otherwise.
On the other hand, the aggregate-address statement is used to aggregate routes that are already present in bgp table. If the routes are not already present in bgp the aggregate-address statement will not work.
