BGP aggregate-address
bellocarico
What is the difference in using an attribute-map instead of a route-map as paramenter of the
bgp aggregate-address command?
From the "?"
attribute-map Set attributes of aggregate
route-map Set parameters of aggregate
Thanks to read.
owaisberg
attribute-map and route-map are equivalent
and do the same job, so no difference whatsoever beside the name.
HTH,
OW
* Please rate all useful posts
Friend,
Though they perform the same thing, it should be noted that the attribute-map command can only be used along with the aggregate command and it references a route-map
Whereas the route-map can be used with almost anything for implementing the routing policy.
HTH, rate if it does
Narayan
Narayan,
You are correct, however original question
was about the difference between these two
commands when both used with aggregate.
And as per aggregate usage, these two are
identical.
HTH,
OW
